Go Back   Automotive Forums Car Chat > Ford > Contour
Old 11-18-2012, 03:17 PM
coldroadbear coldroadbear is offline
99 ford contour not heating up
I have 99 ford contour that's not heating up. I have replaced the thermostat and flushed the whole system out. The head was replaced before i got it. I would be thankful for any help i can get. at this point this is me
Old 11-18-2012, 11:52 PM
mechhound mechhound is offline
Re: 99 ford contour not heating up
What's not heating up, the engine or the interior of the car? If the thermostat you installed is good, the engine should heat up. A properly working thermostat will keep the coolant from circulating through the radiator until it reaches a certain temperature. If the coolant isn't circulating through the radiator, the engine will heat up.
Now if the interior of the car isn't heating up, something is awry with the heater. Plugged heater core or heater controls not working properly. I should point out the coolant will flow through the heater core as soon as the engine is started if everything is working properly. Of course you won't get any heat until the engine warms up somewhat.
Old 11-19-2012, 12:16 AM
Both are not heating up i should have said that. but i have replace the thermostat 3 times now thinking i did get a bad one. I checked the engine and it goes up to about 140 at the highest. there is no know leaks any where and coolant stays full
