Old 11-17-2012, 09:09 PM
gmbwrenchn gmbwrenchn is offline
95 GA Dome light schematic
Does anyone have a schematic of the dome light for this car? Thanks
Old 12-17-2012, 07:55 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 95 GA Dome light schematic
Welcome to AF !
What are you needing this for ?
Their are not that many wires up there, a hot and a ground. With a volt meter or a test light, you can resolve which is which.
1999 Grand Am SS 3.4 OHV
Old 05-18-2013, 11:49 PM
Issue I've had is the dome light stays on all the time. Any ideas? Door switch? Dome light dimmer switch? This car does NOT have a plunger type switch in the door jamb. What's the most common. Thanks.
Old 05-19-2013, 09:32 AM
Tech II Tech II is offline
Is only the dome light on, but the interior footwell lights are off?
Old 05-21-2013, 08:04 PM
No they stay on as well, thanks.
Old 05-21-2013, 08:24 PM
Well, if all the interior lights are on with the dome, I doubt it has anything to do with the dome light.....what you need is a schematic for the interior lights.....the normal inputs that would turn them on, are the dimmer switch, and any one of the door switches......need a schematic to see if a lamp module or BCM is used by this year vehicle.....
Old 05-23-2013, 05:14 PM
first you need to check the dimmer switch on the dash, this will/can make your lights stay on if its damaged or stuck in the "ON" position.
Then check the dome light its self and make sure the 3 way switch is not damaged or shorted out. then check the door switches and wiring and contacts on any plugs-ins, they can get corroded and cause problems.
Ive seen these with cracked and shorted wiring between the door to car, they run thru the rubber boot. remove your door panel and you'll see the wires going to the door jar switch.
And here is a wire diagram, it might help you test the circuits.
Old 05-26-2013, 08:29 PM
Thanks for the info and ideas! Appreciate it.
