Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 11-16-2012, 09:57 AM
scallaway scallaway is offline
1988 Delta 88 3800
I have a 88 delta 88 3800. Most of the time when i start it, it wants to roar, around 2000 rpm. If I let it run long enough it will over heat and blow aintifrieeze out of the resivore. The cooling fan wont kick in and it continues to roar like it is still warming up. Ocasionally it will start and warm up and idle like it is suppost to. I have hot wired the colling fan and it works on low and hi. any one have any ideas?
scally
Old 11-16-2012, 06:23 PM
Tech II Tech II is offline
Re: 1988 Delta 88 3800
Cold engine will be around 1000-1200 rpms, but within a minute is should drop less than that, until it finally reaches normal 600-700 rpms....
If it is as high as 2000 and stays there, there are several things that can cause this....a vac leak.....a bad IAC......throttle plate is stuck open due to gunk in the throttle body,etc., .....
Scanned for codes?
