Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 11-16-2012, 09:42 AM
washind washind is offline
Cruise & Door locks
2003 Envoy XLT SLE. After having my transmission rebuilt, my cruise control only engages about 10% of the time and only at speeds below 70KM. Coincidentally, my doors locks also fail to open when I put the vehicle in Park. The transmission folks say its not their problem so would appreciate any diagnostic tips.
Might not be related, but also coincidentally changed the battery after it failed twice. No PCM codes set or pending.
Old 11-16-2012, 07:19 PM
maxwedge maxwedge is offline
A990 racer
Re: Cruise & Door locks
This could be a bcm issue, you need to scan it with a high liner scanner that can access the bcm.
The Following User Says Thank You to maxwedge For This Useful Post:
washind (11-19-2012)
Old 11-19-2012, 09:39 AM
Thanks for the tip. Apparently there is a 'pindle switch' on the side of the tranny that transmits gear selection that might be intermittent. I've ordered the part and will report the outcome. Oh, yeah, now notice that the dash display of gear shift selection only shows 'R' & '3' (not Park, Neutral, etc.).
Old 11-19-2012, 10:06 AM
A990 racer
Prndl is the right term, but this is expensive guess work, no?
Old 11-19-2012, 11:17 AM
PRNDL - too funny. So far only 60 bucks, tax in, for the diagnosis, straightening a bent bracket & road test. Hopefully the transmission shop will swap the Prndl thingy as part of the warranty. I'll let you know tomorrow.
Thanks again.
Old 11-20-2012, 10:02 AM
The transmission shop replaced the Prndl unit with a new OEM product - everything now works; no charge.
Old 11-20-2012, 01:05 PM
A990 racer
Good,, they knew they damaged it during the repair.
