Old 11-15-2012, 02:56 AM
hobby28 hobby28 is offline
Gas Mileage Drop 2008 HD
I have a 2008 Silverado HD with a 6.0 56,000 miles. At the begining of the year I was pulling my race car and getting 12 mpg every trip. I am now getting 9 mpg on a regular basis and even running empty part of the time. I have noticed the exhaust pipe looks more black than it used to. If you rev the truck up it will puff some black smoke. I scanned the truck, it has no codes stored, the ect seems 15-20 cooler than the gauge in the dash, and the O2 sensors keeps fluctuating. What type of readings should I expect from the O2 sensors? I have changed the air filter and cleaned the MAF sensor. What do I need to look for.
Old 11-15-2012, 05:09 PM
777stickman 777stickman is offline
Re: Gas Mileage Drop 2008 HD
From your post my 1st inclination would be replace the ECT. If it's not sending the proper temp signal to the VCM it could be staying in the cold "enrichment" mode.
Try this site for OEM parts. Include your VIN with the query.
http://www.gmpartsdirect.com/
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 11-16-2012, 07:50 AM
j cAT j cAT is offline
check the fuel pressures as well. make sure they are in the correct range. check the regulator that it is not defective.
the ECT/fuel pressure issues may not throw any codes.
with frequent towing I would replace the plugs more often also. use ac delco irridiums.
