Go Back   Automotive Forums Car Chat > Dodge > Caliber
Old 11-14-2012, 03:17 PM
barker23 barker23 is offline
Send a message via Yahoo to barker23
2008 Caliber Tension Pulley
Is this thing possible to change at home or does it take a mechanics shop with a lift to accomplish? Ive tried for days to get even 1 bolt out without any success at all.
Thanks for any help.
03 Chevy Trailblazer LT EXT
04 Silverado Z71
88 Fiero Formula V-6
82 Chevy Corvette
07 Dodge Caliber
Old 11-14-2012, 03:34 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2008 Caliber Tension Pulley
What engine does it have?
Old 11-14-2012, 03:46 PM
gmtech1's Avatar
Zoom and Print Options
1. Raise vehicle on hoist.
2. Remove belt splash shield (3).
3. Remove accessory drive belt See: Drive Belt > Removal and Replacement > Accessory Drive Belt - Removal.
4. Remove accessory drive belt tensioner mounting bolt. Remove accessory drive belt tensioner (8).
Looks like the proceedure is the same for all except the SRT.
Old 04-05-2015, 08:49 AM
thomas514 thomas514 is offline
I've had mechanics replace this part twice and both times it continues to rattle. Almost like the pulley isn't tight enough but its confirmed that when the mechanics install it its tighten adequately. I've of them demonstrated that applying pressure to the pulley with a long standard screw driver made the noise go away even after it was tighten. What can be the problem? I found some used car parts on AM Car Parts website Used Car Engines
Old 01-16-2016, 07:54 AM
rhandwor rhandwor is offline
You can purchase a new tensioner with a new spring. Most parts stores sell them.
