Old 11-14-2012, 03:07 PM
frehol frehol is offline
Break Line size
Hello!
Blazer 1995 4wd 4wal v6 vin z 4l60e
I need to replace the break line (pipe?) that goes from front to rear where it attaches to a hose. It runs on top of the frame, left side.
Do anyone know the dimension of the pipe and fittings?
Thanks,
Freddy
Old 11-14-2012, 03:17 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Break Line size
Most likely 1/4" or 3/16". If you can cut a piece off with a tubing cutter, you can take it to a parts store and match it up.
Old 11-16-2012, 08:42 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Break Line size
Also remove the fittings on each end of the line and get brake line set up with same fittings.
Some are metric double and bubble flares.
And mesure how long line needs to be.
You may need to put several lines together to get from front to rear.
MT
