Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 11-14-2012, 12:27 PM
heymax heymax is offline
Spark Plug Seals
Is it me or are those seals a pain in the butt to replace. Does anyone have a good way of replacing them.
Old 11-29-2012, 04:53 PM
artbuc artbuc is offline
Re: Spark Plug Seals
Are you talking about removing old or installing new? You are talking about the sparkplug tube seals that fit into the valve cover heads?
I used a bolt with big washers and a nut to pull the new seal into place. One washer on the outside of the valve cover and one washer on the seal. Worked like a charm. No need to drive it with a hammer at all. Most important thing is not to push it in too far or you will not have enough overlap with the sparkplug tube to create a good seal.
Old 12-20-2012, 09:44 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
What engine?
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
