Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 11-12-2012, 08:38 PM
XWrench3 XWrench3 is offline
front differential oil level???
i changed the front differential oil a few moths ago, and now it is leaking oil pretty bad from the axle seals. i think i may have over filled it. the level plug sits quite high on the differential, but that was where i figured i had better fill it to. is this the correct level? if not, how do i set the level correctly. i would like to make sure i have the level correct before i start ripping the entire housing out to replace the seals, and then have to do it all over again because i put to much oil back in it again! if it is correct. then i have a big job ahead of me. and yes, i did check the vent hose to make sure it is venting properly. that would have been to easy. welcome, but to easy.
Old 11-21-2012, 07:09 PM
kenman1717 kenman1717 is offline
Re: front differential oil level???
oil level should be at level of hole, just dribbling out.
Old 11-23-2012, 05:52 PM
actually, i found it in a manual. it is supposed to be 1" BELOW the hole when everything is "cold" and at the hole (level) when everything is up to normal operating temperature. which i guess is great for repair shops, but kind of a pain for home mechanics. first of all, taking it for a drive before checking the level, then getting the vehicle raised up and leveled.
