Old 11-11-2012, 07:11 PM
88Porsche944 88Porsche944 is offline
Need an alternative to Tamiya Primer
What would be the best alternative for Tamiya Primer. I'm using TS paints. Every time I go the LHS, the are out of stock.
Thanks,
Trevor
Old 11-11-2012, 08:33 PM
Adam Baker Adam Baker is offline
Send a message via AIM to Adam Baker Send a message via MSN to Adam Baker Send a message via Yahoo to Adam Baker
Re: Need an alternative to Tamiya Primer
I like using Duplicolor sandable primer. Gotta be a little careful when you down it down b/c it can cause crazing and ghosting of mold seams if you put it down too heavy. I try to put down a couple of light coats and then put down a good cover coat.
The Following User Says Thank You to Adam Baker For This Useful Post:
88Porsche944 (11-11-2012)
Old 11-11-2012, 10:11 PM
Pugnuts Pugnuts is offline
totally agree, works just as good, is very fine, and cheaper.
The Following User Says Thank You to Pugnuts For This Useful Post:
Old 11-11-2012, 10:47 PM
Vric's Avatar
Vric Vric is offline
Mr Hobby primer is your best bet
Old 11-12-2012, 12:04 AM
hirofkd's Avatar
hirofkd hirofkd is offline
Ditto to Mr. Hobby Primer/Surfacer (bottle or spray), especially the 1200 grade, which is finer than Tamiya Primer.
Hiroaki Fukuda
Old 11-12-2012, 10:28 AM
ZoomZoomMX-5's Avatar
Another vote for Mr. Hobby primer.
I'm airbrushing Mr. Surfacer 1000 and it's also much smoother than Tamiya rattle can fine primer.
My Fotki Album
Old 11-12-2012, 10:43 AM
Thanks all for the replies.
Having never used Mr. Hobby, does it need to be thinned before airbrush use?
Trevor
Old 11-12-2012, 01:05 PM
Trevor
Yes it does, quite a bit. Best to use Mr. Color Thinner or Tamiya Lacquer Thinner for best results. Something about the hobby thinners that make the paint flow perfectly vs. using automotive thinners. To me, worth the added expense.
My Fotki Album
The Following User Says Thank You to ZoomZoomMX-5 For This Useful Post:
88Porsche944 (11-12-2012)
Old 11-12-2012, 09:18 PM
935k3's Avatar
935k3 935k3 is offline
If you have an airbrush Alclad has a very good, smooth and very fine light grey white and black primer already thinned and ready to spray. I use it on all my small parts that need painted because I do not like painting bare plastic. A large 4 oz. bottle is about $9.00. It does seem to go on smoother with a good gravity feed airbrush at about 15 PSI. Bob it is good to see you back.
The Following User Says Thank You to 935k3 For This Useful Post:
Old 11-16-2012, 04:32 PM
manos13 manos13 is offline
Dear friend,
May I suggest you use Testors(Model Master) primers (white or grey) and mix it up with Nitro Thinner from any paint shop?It works perfectly and becomes very smoothly.just leave one day long to dry, before you use TS Tamiya on it.It's also a cheap way.The second way is Mr Surfacer 1000 mixed with Levelling Thinner.
Old 11-16-2012, 06:36 PM
SmokeyR67 SmokeyR67 is offline
If you have an airbrush I have to second Alclad primer - it's the best out there bar none, but if you need to buy it in a rattle can, Mr Surfacer is great too.
Old 11-16-2012, 07:22 PM
rallymaster's Avatar
You can also find primer in Citadel paint range.
It works well, pure white, but it's only available in spray can.
Phil
