Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 11-10-2012, 09:05 PM
Ed_Strong's Avatar
Ed_Strong Ed_Strong is offline
Son of a Mechanic
Need a good 12V feed from the ACC Switch
2005 Malibu LS (Epsylon Body) Where can I get a good 12V feed from the ACC Switch. I tried the Cig Lighter but it's live with a constant 12V feed! The Radio plug also only has a constant 12V wire and no others feed 12V when ACC is switched on.
Just trying to add an FM Modulator to the radio so I can plug my MP3 Player
Current Rides:
2018 Honda Pilot EX-L - 3.5L V6 -{|}- 2004 Toyota Matrix XR 4WD 1.8 I4
________________________________________
Past Rides:
2000 Ford Windstar LX - 3.8L V6 SFI - {|} - 2003 Ford Expedition XLT - 4.6L V8 SFI
2005 Chevrolet Malibu LS - 3.5L V6 SFI - {|} - 1991 Chevrolet Corsica LT - 3.1L V6 MFI
1995 Dodge Grand Caravan SE - 3.3L V6 MFI - {|} - 1980 Ford Mustang - 3.3L L6 1BBL
Old 11-11-2012, 10:02 AM
DeltaP DeltaP is offline
Re: Need a good 12V feed from the ACC Switch
The "RDO-ACC" fuse,(10 amp), should be 12v when key is in the "ACC or RUN" positions. The fuse block is located in the left dash end cap,accessible when the left door is open. The cover pops open exposing the fuse block and the fuse location legend is molded into the inside of the cover. It's a yellow wire leading to the radio harness. Careful if you're taking the power off the radio harness. Theres 2 yellow wires on the radio harness plug. The other is for the LR speaker. Make sure 10 amps can handle it. Hope this helps.
The Following User Says Thank You to DeltaP For This Useful Post:
Ed_Strong (11-11-2012)
Old 11-11-2012, 02:35 PM
Ed_Strong's Avatar
Son of a Mechanic
Well the modulator unit I'm installing has a 2amp fuse built in, so it should be OK! I'll check that "RDO-ACC" fuse for current only when in ACC and RUN pos and use it if it fits.
I'm provisionally running it from the Cig Lighter and even tho the modulator unit has an ON-OFF switch, I would rather use the ACC feed, I just don't want to find a dead battery one day after mistakenly leaving the unit ON for a while.
Thanks for the help DeltaP
Current Rides:
Past Rides:
