Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 11-10-2012, 12:50 PM
Primemaster Primemaster is offline
Can I just disable the power sliding doors on my montanna sv6 2007?
I'm wondering if I can disable the sliding doors? The problems are endless, cables hanging etc, right now the door is open and will not close and it's about to rain, pls help
Old 11-10-2012, 01:20 PM
Tech II Tech II is offline
Re: Can I just disable the power sliding doors on my montanna sv6 2007?
Just turn the overhead switch(s) to off........if cables are hanging and cause a problem with closure, the cables can be removed and you would just have a manual sliding door.......usually when cables have a lot of slack, the clutch mechanism is shot, and expensive to replace......
Old 11-10-2012, 02:33 PM
Can I disconnect these cables or should I just cut then? Should I be disabling any electronics with this change over back to manual?
Old 11-11-2012, 02:34 PM
You don't have to disable any electronics, just turn the overhead switch(s) to off.....
Don't have to remove cables, if the door will open/shut manually......
