Go Back   Automotive Forums .com Car Chat > Chevrolet > General Discussion
Old 11-08-2012, 02:45 PM   #1
gonoles12
Metal to metal scraping noise
Have a 02 Chevy Suburban. Getting a loud metal to metal scraping or grinding noise from engine. This happens while driving at constant speed then slightly applying or decreasing throttle. It lasts only for a couple of seconds. I was able to get same sound in "drive" with brake applied and then applied throttle (adding slight load to engine)
I replaced all belts and pulleys on engine thinking might be the problem. Any thoughts?
gonoles12 is offline   Reply With Quote
Old 11-08-2012, 06:58 PM   #2
maxwedge
A990 racer
Re: Metal to metal scraping noise
Usually diagnosing issues like this on the net is less than guesswork, anyway may be a exhaust shield grounding/loose?
maxwedge is offline   Reply With Quote
Old 11-08-2012, 07:01 PM   #3
gmtech1
gmtech1's Avatar
I agree with Max...tough to tell on this end, but does sound like maybe a exhaust shield.
gmtech1 is offline   Reply With Quote
Old 11-08-2012, 08:14 PM   #4
gonoles12
thank you both, I thought of that but the sound is not a vibration nor rattle rather a squeal or high pitch grinding sound??
Old 11-08-2012, 09:21 PM   #5
Tech II
Compressor clutch?
Tech II is offline   Reply With Quote
Old 11-09-2012, 08:58 AM   #6
j cAT
If ths occurs when the vehicle is in motion then it maybe in the drive train. the transfercase when failing makes these type noises.
then theres the drive shaft joints.
j cAT is offline   Reply With Quote
