Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-07-2012, 03:18 PM
WhiteRodeo4x4's Avatar
WhiteRodeo4x4 WhiteRodeo4x4 is offline
4x4 light flashing on dash
Just had the 1st chance to put car in 4x4 and noticed that the 4x4 light on the dash just flashes. I do hear a noise from under the car like it is engaging something but the light flashes.What could this be? The lever will go into 4 wheel low and appears to be OK. Is there something I should be doing?? Thanks
Just a quick follow up. When I activate the button on the dash I can hear something happening under the truck,and I am able to put the truck in 4wheel low. But I am still not getting the front to engage. Any ideas would be appreciated.
Old 11-11-2012, 08:54 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 4x4 light flashing on dash
http://www.walkerdowney.com/ryanendres//isuzu/#faq68
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 11-11-2012, 05:24 PM
Originally Posted by amigo-2k View Post
OK so today I climbed under the car and had my wife flick the 4wd switch on and off. The shaft that runs from the transfer case to the front unit does lock up and BUT the front unit on the L/S axel housing does nothing.I believe this is what locks the 4x4 unit to the housings. I am thinking this is the culprit and needs to be pulled off and cleaned. AM I RIGHT???? Thanks for replies 2001 Isuzu Rodeo V6 Automatic SOTF 4x4 Would take any advise to what to do. because it sure as hell isn't going to work it ou by itself.
Old 11-11-2012, 05:42 PM
Isuzu Guy
you are correct ... it needs to come apart and be cleaned....
http://www.planetisuzoo.com/articles..._Fly_Mechanism
-Ryan
Isuzu Moderator
Car Show Tips
Old 11-11-2012, 06:32 PM
Is there any special things I need to know or do before unbolting this from the housing. Should I replace the Vac hoses...what do I need to look out for when taking this apart. Thanks.
Old 11-11-2012, 08:08 PM
Isuzu Guy
I've never have done it before, but I would suggest you post on planetisuzoo.com (a ton of isuzu owners there).
-Ryan
Isuzu Moderator
Car Show Tips
Old 11-12-2012, 09:06 PM
So after taking a daily stroll through my favorite salvage yard I came to the conclusion that if the 4x4 on the fron axle has an electric motor to switch it to 4x4 there wont be a vacuum system. I guess my next step is to saerch for an electric actuator on the front housing. I am tempted to remove it but don't want to open a can of worms and see stuff poping out. Would rather experiment on a donor at the JY first. I see that these are a very common problem and prone to seizing and rusting up if not used every month or so. Oh and I actually found a switch for the Fog/Driving lamps.
