start prob 98 century
I have intermittent no start prob.
Once in a while I turn the key and get nothing.(no click/no dim of lights/just effect from key turn./ I wiggle the wires to the starter and it will start.(sometimes 2-9 tries) I think I need to change the wires.(power) It looks like there are a lot of wires in this operation. So it looks like the 2 wires (start sig. and other one) have been spliced. Just wondering what is involved with this kind of wire change out. Cheers Viper1 |
Re: start prob 98 century
Before you do anything you need to check if you have power to the main feeds in the under hood fuse panel.
| The Following User Says Thank You to maxwedge For This Useful Post: | ||
stripe (11-07-2012)
I would turn the key to "on", don't crank....observe the SECURITY light, it should go out after 3-5 seconds......if it does, then see if car cranks and runs....if it doesn't, then take the "repaired" wires apart and do a proper repair....
If the light stays on, chances are the wires to the ignition lock cylinder have a break in them....if insulation is intact, have an intermittant problem......when it breaks completely, it will never start.... Check for codes? |
| The Following User Says Thank You to Tech II For This Useful Post: | ||
stripe (11-07-2012)
I started it and stopped it over 100 times with the wheel pointing straight ahead and no problems. Then forgetting I turned it off with the wheel turned (no start) But it did start right up after I wiggled the wires close to the starter. I have no idea how the two could be related. only code is po442(minor leak) Cheers Viper1 |
If I saw some kinda repair or splice work on the wiring harness thats right where I would go initially.As mentioned before take the "repaired" wires apart and repair properly.Old repair might have corroded or loosened up so repair properly with the correct guage wiring,inspect and/or replace the wiring end terminals to the starter with heat shrink terminals and seal all wiring repairs with heatshrink tubing not electrical tape.
