Old 11-06-2012, 05:55 PM
steeler12 steeler12 is offline
2000 chevy misfire cylinder 8
So I have A 2000 Chevy and i keep getting a code saying i have a misfire on cylinder 8. i have replaced the spark plug, i have replaced the coil. this code is still showing up. what else could this be?
Old 11-06-2012, 07:33 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2000 chevy misfire cylinder 8
The plug wire maybe? Injector? If it continues you should run a compression check, there may be a valve issue. Also could have carbon build up on the piston or valves or even a worn cam lobe
Old 11-07-2012, 07:50 AM
j cAT j cAT is offline
what is the code ? how many miles ? what engine ?
