Old 11-05-2012, 08:50 AM
Brent S Brent S is offline
Window Switch
I need a new Left side power window switch on my 99 2-door GTP.
The old parts catalog seems to list: 10404698, but the various websites show a 19207825.
Anyone know the difference, or correct part number?
-Brent
'99 GTP
Old 11-05-2012, 03:58 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Window Switch
Don't know about part numbers, sometimes they change due to revisions and design changes. Also part numbers vary a lot between ACDelco and Chevrolet numbers.
I've found a replacement for you available form autozone, a bit pricey though
CLICK HERE
EDIT: I just looked it up and found out the switch was used in grand prix and sunfire vehicles; I'm guessing it should be easier to get one from a sunfire than finding a 2 door GP; I haven't been able to find one around here and I'm in need of the same switch as yours. Now that I know it I might try searching the junkyard for sunfire's.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 11-05-2012, 04:25 PM
aleekat aleekat is offline
Re: Window Switch
About $41 at rockauto.com
Old 11-24-2012, 09:42 AM
DrRadar DrRadar is offline
Just a guy
Re: Window Switch
I've been able to do a quick fix to a misbehaving window switch. If you pop-off the switch lever (the plastic that you actually touch), you'll see a plastic, spring-loaded "fulcrum" on each of the left and right sides of the switch. When new, these fulcrums are apparently semi-circular. I have found that they wear and flatten out, which then interferes with proper functioning. I've swapped those little plastic fulcrums with other window switches (for example, to get the driver's window switch to work, swapped with the passenger switch).
Lloyd
18 Charger ScatPack 392
18 Lincoln Navigator L (Hers)
98 Grand Prix GTP Sedan (RIP)
99 Grand Prix GTP Coupe (to the moon)
05 Wrangler Unlimited (Junior's)
03 Explorer XLT (Sissy's)
