Old 11-03-2012, 09:32 AM
anotherwagner anotherwagner is offline
Exclamation 1998 C1500 5.7 Misfiring Rough Idle
I was driving down the interstate and sped up to pass a car once I started to slow down the CES light came on and the truck started to shutter really bad. I got it to a scanner and it said misfire Cylinder 6 and he suggested that i change the cap rotor plugs and wires since it has been a long time since it had been done. I did so and and the problem has continues. It idles real rough acts like it is going to die, then under power it smooths out a little but you can still tell it it where. Above 3000 the CES blinks until you slow down and the the scanner still says misfire cylinder 6. Any suggestions.
Old 11-03-2012, 11:15 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1998 C1500 5.7 Misfiring Rough Idle
Originally Posted by anotherwagner View Post
i was driving down the interstate and sped up to pass a car once i started to slow down the ces light came on and the truck started to shutter really bad. I got it to a scanner and it said misfire cylinder 6 and he suggested that i change the cap rotor plugs and wires since it has been a long time since it had been done. I did so and and the problem has continues. It idles real rough acts like it is going to die, then under power it smooths out a little but you can still tell it it where. Above 3000 the ces blinks until you slow down and the the scanner still says misfire cylinder 6. Any suggestions.
check compression and check for vacumn leaks or stuck egr valve.
MT
Old 11-04-2012, 12:16 PM
Schurkey Schurkey is offline
Find another technician; someone who, when told the problem is on Cylinder 6, doesn't try to fix it on cylinders 1 through 5, and 7 & 8.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 11-04-2012, 06:32 PM
j cAT j cAT is offline
the valve springs. check compression. not uncommon.
Old 11-05-2012, 11:36 PM
dirtautoguy12 dirtautoguy12 is offline
This is just something simple but also check that the spark plug wire to cylinder 6 is tight. And that the dist. Cap is tight too. Although usually if it's the cap or rotor it's multiple cylinders.
