Old 11-01-2012, 03:53 PM
jesseb11 jesseb11 is offline
noise coming from front of engine
2000 GMC Jimmy 4x4
Theres a noise coming from the front of the engine. Specificly sounds like its coming from the front left side near the starter. Dont know what it is. Usually hear it as soon as you start it up. Somtimes will get louder when you push on the gas. Need Help
Thanks, Jesse
Old 11-01-2012, 04:44 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: noise coming from front of engine
Originally Posted by jesseb11 View Post
2000 GMC Jimmy 4x4
Thanks, Jesse
Hmmmm...where to start. The starter in located in the right rear area of the motor. Perhaps you meant alternator? What type of noise is it? Squeak...rattle...clunk...ect., noises can be very tough on a forum like this. Remove the belt and see if the noise is there. If not, you may just need a belt. Also while the belt is off, spin the pullys and check for noises. (Eng off while spinning the pullys)
Old 11-01-2012, 05:23 PM
Disreguard what I said about the starter... Its more of a clunk not rattle or squeak. Umm. I Highly doubt its the any of the belts by the noise its making... The noise gets quiet at some points but then loud at others. Usually gets pretty loud when you press the gas then let off of it.
Old 11-03-2012, 11:25 AM
goser goser is offline
At a guess, sounds like it could be a motor mount?
'01 Chevy Blazer ZR2 4x4 VIN=W
'80 Yamaha XJ650 Maxim
'08 Jeep Patriot 2.4L
