Old 10-24-2012, 10:17 PM
Tgamey Tgamey is offline
1991 Ford: Battery drain caused by both engine and meter fuses
I have a 1991 ford laser thats battery has been found completely drained if left overnight..even after several hours. After running a test light, I found that both the engine and meter fuses were involved. Any suggestions on where to go from here?
Old 10-25-2012, 07:00 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 1991 Ford: Battery drain caused by both engine and meter fuses
Do you have access to a wiring diagram for the car? You're probably going to need one to identify which circuits are on those fuses and start isolating them one at a time.
I'm not familiar with the Ford Laser so I doubt I'll be able to help you out with the diagram, unless it's the same as some US model.
-Rod
Old 10-26-2012, 08:25 PM
vgames33 vgames33 is offline
-Rod
The wiki says its similar to our Escort.
Old 11-01-2012, 01:18 PM
shadows shadows is offline
test light is only marginal- might tell you something- might not relate
remove the negitive battery terminal- in somewhat dark- slowly bring it to the terminal- you see a spark- when you in fact know nothing is on-
aftermarket add on's- sterio system- lights- you don't have them correct-
AND- you can remove your good battery, set it on something not the ground or cement for 12-24 hours- and it holds a charge- you install it, there is no spark at the negetive terminal- vehicle turns over strong
some years back auto mechanics who would tackle electrical vehicle problems would get every bit as much as a licensed home electrician-
in short- tracing down/finding the solution/correcting it- could and might cost $35.00 an hour or up
you are asking- as a previous mechanic/business owner- I had one who would take on any vehicle electrical issue- but he expected to be paid for his time
good luck in your internet search of a simple cheap fix-
Tags
battery , drain , engine , fuse , meter
