The Right Day-Time Running Light Not Working
The Right DRL Not Working on my 2005 Venture. I checked the following, also note the turn signal works and the following are ok.
Bulb Bulb Socket Socket harness All Fuses and relays When I turn on the headlights the day-time bulb lights, Stumped
No matter how much you like doing it, if you are getting paid it's a job Last edited by Rolm; 11-01-2012 at 06:58 PM. |
Re: The Right Day-Time Running Light Not Working
It's probably a bad fuse, or relay/resistor to the DRL.
The owners manual might have the locations, see www.alldata.com . I think there's one Relay/resistor for the DRL, and another relay for the lights. |
No matter how much you like doing it, if you are getting paid it's a job |
Once you look at the electrical diagrams on www.alldata.com , it might make more sense.
With today' s auto, each light might be fused. |
Without knowing the year of the vehicle, I won't be much help...
Opps Sorrry It's a 2005 Venture
Is there power on the blue wire at the r/f bulb socket? If not, check the wire at the DRL module, dark blue wire, connector C2 terminal C. If no power, the module is bad, if there is power, then there is an open in that circut between the DRL module and the socket. That wire runs from the DRL module, through the underhood fuse block, to the socket.
It's under the left side of the dash, I think it's left of the steering column (towards the drivers door). It slides onto a bracket and has two connnectors going to it. It's' pretty much square shaped.
I will take a look when it stops raining. Thanks
Go to the dlr/sig light socket and remove the bulb (make sure it is the correct working bulb) trace the ground wire back to see if it makes a good ground to the body.
By looking at the wiring dia this might be the problem. With the left side working normal it says that the DRL control module is ok. Just what i would look at for a start. |
