Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-24-2012, 03:09 PM
comet240 comet240 is offline
00 1500 engine shuts down
so new problem truck doesnt start unless you give gas at same time it runs as long as your foot is on the pedal let go it drops below 1000 rpms and shuts down
you can rev it fine and no engine light so there is no fault
so what is wrong with this truck now?
its a 2000 ram 1500 v8 5.2 engine
Old 10-24-2012, 04:46 PM
Re: 00 1500 engine shuts down
so it has started working again but what sensor would it be? that it can run fine as long as u dont let up off the gas pedal
Old 10-24-2012, 05:16 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
I'd suspect the fuel pressure.
Check out page 1489 of the manual.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 10-24-2012, 05:26 PM
ok ill check when i get home
what normally causes that? i not at home at moment fuel regulator?
Old 10-27-2012, 07:59 AM
AF - Advisor
Fuel pump/filter.
Old 10-27-2012, 02:08 PM
i read skimming but didnt read it all the online book
says fuel filter/regulator is in gas tank does that mean u gotta drop the tank? or can you get at it from a side or so?
Old 10-27-2012, 02:37 PM
i figured if the fuel pump was bad or filter it would shut down while reving engine right? not once you let off the gas pedal
i figured it be the fuel regulator? sinec if you put your foot on gas and you can keep it running at 1000 rpms or less as long as u dotn let go
but then i read somewhere it could be the throttle body sensor??? like its stoppped doing it now and runs fine
so what odds it be a sensor as if it was fuel filter it stop working riight?
Old 10-28-2012, 07:56 PM
AF - Advisor
Wow, my poor old brain is forgetful...
Take some carb. cleaner on a clean rag and wipe out the throttle body.
I've read that crud near & around the throttle blade upsets the thing.
A TPS issue should set a code and the IAC valve too.
Old 10-29-2012, 06:15 PM
ah ok ill do that this week
and what is a IAC?
so i guessing maybe that is the problem the Throttle Postion Sensor
so far driving a 100kms since it wouldnt run and so far no issues go figure eh? lol
Old 10-29-2012, 08:51 PM
AF - Advisor
That would be the Idle Air Control valve, Pg. 1528-1530...mounted near the throttle body & has 3 or 4 wires connected. It responds to the computer signal to maintain engine idle speed.
Old 10-30-2012, 11:36 AM
ah ok and till it fails ill never be able to test for it right?
or can computer aided software that monitors be able to tell me?
as i have a HP Tuner that has scanner software for live data etc
and if so what would be the ranges?
Old 10-30-2012, 05:29 PM
AF - Advisor
I'm sure there's a trouble code for a failed IAC...P1294
Sorry, I don't know the ranges.
Old 10-30-2012, 05:38 PM
ok ill check it tommorow
but the engine light isnt on so would it still retain the code?
