Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 10-23-2012, 08:49 PM
Recoil spring Recoil spring is offline
How to disable ignition for crank test?
When I was a mechanic in the 1980's it was easy to disable a car's ignition to do starter crank or compression tests, just pull the distributor lead wire in the center of the dist. cap.
I have a 2000 vintage 4.6 engine and was wondering the easy way to knock out the ignition to do crank tests, etc. This engine has all the modules resting independently on each spark plug, so no central distributor cap to get to. Is there an easy way, and does it work for Chrysler and GM cars too?
Thanks.
Old 10-24-2012, 12:31 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: How to disable ignition for crank test?
Pull out the fuel pump fuse or relay.
The spark stays and the engine will crank but not run
The Following User Says Thank You to MagicRat For This Useful Post:
Recoil spring (10-25-2012)
Old 10-24-2012, 06:43 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Hold the throttle wide open. This shuts the fuel off and you can crank the engine without it starting.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
The Following User Says Thank You to way2old For This Useful Post:
Old 10-25-2012, 07:53 PM
There was some stuff on the internet mentioning to go after the fuel source, like you guys mentioned. Eventually I may have to do tests down the road and I appreciate you guys letting me know on how to do it. The cars now are a different animal from the vehicles of 1972.
