Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-23-2012, 10:53 AM
comet240 comet240 is offline
2000 ram 1500 abs light and brake light on
hi
i have a 2000 ram 1500 mode truck i had a guy do the brakes i trusted but messed it up he did single flare instead of double flare on the rear lines and was causing the driver back to heat up and lock on while driving and what not found it later this issue but in the mean time i got the ABS light on and the Brake warning system light on, where do i look?
i just fixed the brake lines now and bled them figured get rid of the brake warning light one
so where do i look first on this and i guessing there is no abs for the back? as i dont see a wire for it
and before i fixed it i havent tested it yet braking would shake the whole truck also while driving the whole truck would shake apart i guessing cuz of the single flare lines so thats been re replaced not impressed but the light on its my first truck so not sure where to look for the abs stuff
Old 10-23-2012, 11:39 AM
Re: 2000 ram 1500 abs light and brake light on
alright so the lights finnally went out i guessing it detected right amount of pressure?
i notice they go out when u turn key on but when you start truck they come on then go out so i guess self test?
but i do find brakes still stuck on so i currently taking tire and drum off and going to back off the adjust to beginging again
but for a truck when you put in gear and let off the gas is it supposed to move forward like a car? or is supposed to sit there? as its sitting there currently
Old 10-23-2012, 11:53 AM
so i just pulled both wheels off
noticed that driver back it had adjusted itself but the passanger side adjuster never adjusted
also noticed but didnt notice on driver back
is the pass back the adjust cable seems a bit loose like u can move it up and down with ur finger but u cant get it to adjust the wheel to keep it turning it actually makes the wheel turn back so it doesnt adjust
how tight does it have to be? or is it the spring as u can move that metal bracket with ur finger easily tht clicks into the adjuster
Old 10-23-2012, 04:51 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Sorry, I'm not familiar with your issue but here's a downloadable 2001 service manual.
The download is kinda slow but worth the wait.
http://dl.dropbox.com/u/42304/2001DodgeRam.pdf
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 10-23-2012, 07:50 PM
ah ok ill download it figures have the different issues no one gets lol
Old 10-25-2012, 01:11 PM
i find now that if i start truck lights will stay on but if i shut off truck and start again it will come back on like it has then shut itself off
is that a sensor problem/
Old 10-25-2012, 05:21 PM
vyros vyros is offline
my monte carlo had both lights on to and in my book for it says that if both lights stay on that means that the abs system is nit working but you still have normal breaking
Old 10-25-2012, 05:39 PM
does it say what to do to fix it or whats causing it?
Old 10-25-2012, 08:15 PM
i havent fixed mine yet but i was told it is most likely your abs sensors. they maybe getting stuck causing the vehicle to think that the wheels are locked up, i have yet to run into a problem with these lights on, but if you cant stand them being on then thats where you want to start
Old 10-25-2012, 08:33 PM
ya doesnt bother me just if you start truck they come on then go off or other times start the truck they stay on but if you shut off truck and start up again then they go out
lol figures eh lol
as long as it brakes lol
