Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
View Poll Results: exhaust leak
rough idle 0 0%
exhaust diagram for turbo 0 0%
Voters: 0. You may not vote on this poll
Old 10-22-2012, 08:24 PM
myfirstzcar myfirstzcar is offline
Exclamation 1986 300zx Turbo rough idle, exhaust leak
I am new here, and I hope I am doing this right. I just got a 1986 300zx Turbo. This car is pristine, however I have an exhaust leak (passenger side) that sounds like it is behind timing cover. Exhaust manifold bolts are tight, no cracks, and it is running rough. I am trying to locate a diagram of the exhaust system for turbo models but can not find one. If any one here has some suggestions I would be very grateful. I am the 2nd owner, it has 145,000 miles on it. Replaced plugs, wires, o2 sensor, cap, fuel filter. Please help, thanks.
Old 10-28-2012, 03:18 PM
longlivetheZ's Avatar
longlivetheZ longlivetheZ is offline
Send a message via AIM to longlivetheZ Send a message via MSN to longlivetheZ
Re: 1986 300zx Turbo rough idle, exhaust leak
Shoot me a PM and I'll hook you up. Think I still have a FSM for the Z31 around here somewhere.
Who cares what's in your wallet...what's in your garage?
VG30ET in process of rebuild on left and my 88 300ZX NA, 2 Seater, 5-Speed...my 3rd Z31
Hope you can see the tiny pic...AF reduced the size limit!
Beer is living proof that God loves us and wants us to be happy. --Benjamin Franklin
Old 10-28-2012, 03:22 PM
danielsatur danielsatur is offline
You could probably use a smoke test to pin point an exhaust leak.
Any leaks up-stream of the O2 sensor will give a false signal to the ECU/PCU which will formulate a bad air/fuel mix.
I wonder if the Turbo is working!
Also do a catalytic converter back pressure test.
Tags
exhaust , idle , leak , miss , rough
