Old 10-22-2012, 05:27 PM
jova2003 jova2003 is offline
Dodge Gran Caravan stops while driving
I have a 2003 Dodge Gran Caravan and while I was driving it stopped on me. It will turn on but once you put it in gear it will turn off and wont turn back on. I have replaced the fuel filter and fuel pump.Any help would be appreciated.
Old 10-22-2012, 11:53 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Dodge Gran Caravan stops while driving
Work in reverse?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 10-23-2012, 01:46 PM
Sometimes it does. Other times it will turn off when I put in reverse.
Old 10-24-2012, 12:32 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
"It will turn on but once you put it in gear it will turn off and wont turn back on."
When it won't "turn back on" are you saying the engine won't rotate when you try to start or it will rotate but won't start?
I'm leaning toward a torque converter that's locked up but I'm a bit low on transmission knowledge. I'm not sure how you prove that. The only fix for a locked up torque converter when you're not seeing the check engine light and have no codes I have come across on the net is to replace it. That's big bucks. You're going to be better off having a tech diagnose it. Maybe someone with some know how can jump in here and give you that silver bullet.
