Old 10-22-2012, 10:14 AM
SirGreggins SirGreggins is offline
Exclamation Not sure what the cause is? Please help
I drive my girlfriends' 2002 Alero 4 cyl and at 101K miles the timing chain snapped. I took the motor apart and replaced all the bent valves, as well as the chain, guides, sprockets and every other part associated with it which came in a kit. At 106K miles the car would not start and the mechanic i had the care towed to is saying its the timing guide. He said "a lot of people dont replace it when they do this job." Well, i did replace it along with everything else including gaskets. Any idea what would cause this to happen after only 5K miles from being fully replaced. I dont really want to replace it again for it to only go another 5K. Please help. Thanks
Old 10-22-2012, 06:45 PM
maxwedge maxwedge is offline
A990 racer
Re: Not sure what the cause is? Please help
Ok won't start, got spark, fuel pressure at the rail, injector pulse?
Old 10-22-2012, 08:29 PM
just heard from the mechanic and he's telling me that the guide is the problem. everything else as far as fuel, spark etc is fine. I'm just wondering if i got a defective part when i went to replace the old guide.
Old 10-23-2012, 06:12 PM
Tech II Tech II is offline
How in the world would a guide prevent a car from starting?,,,,,,was the engine making a slapping noise in the timing chain cover?
I assume this is an Ecotec engine? Kits I see are new cam sprockets, new crank sprocket, new chain, new tensioner, and new oil orifice....never saw a kit with guides.....they were only replaced individually if they were worn....
You have spark on all 4 cylinders? Fuel pressure is OK? Did he check compression?
If all ok, then injector pulse is next.....
Is it possible that this is a PassLock problem? Vehicle is not getting a fuel enable signal to the PCM?
Old 10-24-2012, 03:39 PM
http://www.autopartsnetwork.com/shop...FREx4AodeHAAhQ
The mechanic said he would change the oil (which needed to be done anyways) and the guide which made the chain slip causing issues for $75. i'm going to pick it up today. Not sure how the guide was making it not start but they sent a pic of the broken guide i installed. looks like i got a defective part
Old 10-24-2012, 06:31 PM
i just got the car back. It was the tensioner that went. Took them a week to determine that. This is why i always do my own work when i'm at home and have tools
