Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 10-21-2012, 11:09 AM
bronco1960 bronco1960 is offline
stay running
Will not stay running when the key is in the run position. The person at rebuild the transmission change the manual lever position sensor so I had to change the cannon plug could I get the wire mix up or is the switch not adjusted right 1991 e4od 351
Old 10-21-2012, 11:12 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: stay running
What model year is the Bronco?
Engine size?
Manual or Automatic transmission?
The Following User Says Thank You to MagicRat For This Useful Post:
bronco1960 (11-24-2012)
Old 10-21-2012, 11:32 AM
Re: stay running
Engine size?
e4od 351 1991
Old 11-24-2012, 10:50 AM
Smile Re: stay running
Originally Posted by bronco1960 View Post
e4od 351 1991
fix the ignition switch
