Old 10-19-2012, 07:19 PM
acorn57 acorn57 is offline
chev.s10/ zr2 package/ 4wd
I have a Chav.s10 /2001/ zr2. //4wd I have about 5 inches of stearing slop. What do I need to do to fix the problem?
Old 10-20-2012, 08:28 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: chev.s10/ zr2 package/ 4wd
First look for where the slop is and then repair that place.
Or take it to a repair shop and let them check it out and or fix it.
MT
Old 10-20-2012, 09:08 AM
j cAT j cAT is offline
the steering gear is the usual cause of this. first you must have the complete front end steering arms/ball joints/tie rods/idler arm/pitman arm tested for excessive wear.
if the steering gear does require replacement get a scrap yard unit rather than a rebuilt one. many have had problems with the rebuit ones failing quickly .
trying to adjust the box gear play will not work. the gears if worn are the problem . this is because the fluid was never changed or contaminated with water.
at this time check the front hubs and control arm bushings for wear.
