Old 06-05-2003, 05:09 PM
91civhatch 91civhatch is offline
finally got my mpfi harness YAY!!!!
K guys im all good to go now my question is im going to swap my entire harness if i do so is it still necessary to swap wires on the ecu harness and run the other 2 out to the engine bay???`
Old 06-05-2003, 06:46 PM
come on guys alittle help
Old 06-05-2003, 07:21 PM
GTA's Avatar
GTA GTA is offline
Whee..
the dx dash harness does not join up with the si engine harness. you need to use stuff from the mpfi si harness to convert you dx harness.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 06-05-2003, 07:42 PM
so i have to run the wires anyway what a pain in the poop hehehe thanks man. any easy ways for me to get around this?
Old 06-06-2003, 02:52 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
its not that hard in the first place. since u got an si harness, u have the resistor box wires already there. and just gotta swap the dist plug to match the mpfi dist plug and just match up the wires. and u gotta lengthen the tps wires, well since u got a spare tps with a good length of tps wire, just cut the tps off with alot of wire and just splice them together, same thing with the sensor on the back. then u got b/y and b/g wires which u can use to run to the shock tower. and u got extra connectors so u got put a connector on the shock tower. idk if youll have enough wire to run it to the ecu, i just got a b/y and a blue wire to run to the ecu, of course b/y to b/y. plus u got extra wire to run the injector wires form the ecu through the connector and to the injectors. only thing from there is just gotta worry about the ecu and the changes needed there
if u got any questions, i have done this recently for a b18a, so just hit me up if u need any questions
Team Lonely Drivers
