Old 10-15-2012, 09:36 PM
Ffrog Ffrog is offline
2001 Intrigue power window switch
2001 Intrigue, 3.3L I believe the switch to the driver side power window controls died. Only the driver's window will not work, and was working fine until it suddenly stopped part way. All the other windows work fine. I assume it is the switch component. I was looking for a diagram to see which wires from the 4-switch control operate the driver's window to test them to see if they are faulty before ordering a new 4-switch component. Does anyone have a wiring diagram?
Old 10-16-2012, 08:59 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2001 Intrigue power window switch
Old 10-16-2012, 06:35 PM
Sorry, the links do not work for me.
You are not authorized to view the requested information.
Old 10-16-2012, 07:16 PM
Tech II Tech II is offline
If you can remove the switch from the door, just backprobe a test light to to connector C1 harness, wires E(dk blue) and D(brown), with switch still connected.....
When you press the switch down, it will light for a long time due to the express down module.......momentarily touch the up button and it should go out......now, press the up button and it should light as long as you hold the button.......if the test light acts this way, you need a motor......if it doesn't light in both directions, you need a switch.....
