Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 10-15-2012, 08:30 PM
mansopoor mansopoor is offline
Strobe Light Kit
I have a 2002 Sierra Z71 OFF ROAD ext. cab and I want to put hide away strobe lights in my truck. I seen them on Ebay but I want one that is remote so I don't have to be in the truck to use it ( I can stand outside my truck and turn them on). Anyone got any ideas.
Old 10-16-2012, 05:21 PM
phipps phipps is offline
I'd set them up to run off a relay that can be activated remotely, ie a key fob.
Old 10-16-2012, 05:23 PM
Re: Strobe Light Kit
Thank for the reply but I'm not sure what you mean or how to do it.
Old 10-16-2012, 05:29 PM
You would buy and install your strobe light kit but rather than running the strobes through a switch you run them through a relay that can be turned on/off using a wireless transmitter. I'm sure if you do some searching online someone makes a wireless relay set-up.
Old 10-16-2012, 05:31 PM
Sound good, thanks for the input
Old 10-16-2012, 05:32 PM
Something like this:
http://bit.ly/TrSuY9
Old 10-16-2012, 05:34 PM
Here's an even better one:
http://bit.ly/RNIxYY
Old 10-16-2012, 05:43 PM
This one looks much better. The one I'm looking at is on ebay and it has 8 bulbs and 7 or 8 different strobe flashing, not sure if I mentioned this earlier but I can install the strobes into my truck and get them running but the wireless stuff I have no idea on how it work or how to hook it up so all the strobe flashes work from the remote, sorry but I just don't understand
Old 10-16-2012, 06:01 PM
Rather than hooking the strobes up to a switch in the cab to turn them on/off you wire them through the relay. Then you turn them on/off using the remote key fob. The relay kit should come with directions on how to wire the lights through it.
Old 10-16-2012, 06:04 PM
Ok thanks I will send an email to the seller to find out some of the things about it, and again thanks so much, once I get them up and working I will post a video of them
Old 10-18-2012, 06:21 AM
Sounds good!
Old 11-14-2012, 05:12 PM
Did you ever get the strobes installed?
