Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 10-15-2012, 11:48 AM
badtransam86 badtransam86 is offline
2003 dodge neon crankshaft position sensor
I went to advance auto parts the other day my car kept cranking so they hooked there ob scanner to it and got a reading crankshaft position sensor malfunctioning and they got some reading with the gas cap I forgot what they said about that but I installed a new one with the battery terminals off so I started it up it ran fine for about three days now its back doing the same thing so could they be something else triggering this I even had the codes reset still nothing
Old 10-15-2012, 12:03 PM
jdl jdl is offline
Re: 2003 dodge neon crankshaft position sensor
If it cranks good but won't start, have a helper crank it while you visually check for spark at the spark plugs. If you have spark everywhere, check for injector pulse.
Check the crank sensor wiring circuits, ref voltage--ground--signal. Some sensors share ref voltage and ground with other sensors. It is possible another sensor that shares those circuits could cause a problem. Check the cam sensor.
Old 10-22-2012, 09:52 PM
i have got everything checked out i bought a intake air temperature sensor the only one showing on a obd2 scanner i replaced that it worked good all weekend and when i put gas in the car it quit starting normally so i went all day driving it and i put some more gas in it i got back in it and it started up as soon as i clicked the key over could this be related to the gas cap i let the car set for a while i took the gas cap off and put it back on turned it three times and got in it to start it it started normally
