Old 10-15-2012, 04:22 AM
dynosam's Avatar
dynosam dynosam is offline
Tamiya HG Trigger Type Air Brush
Hi Guys,
Would this be a good first airbrish. Would it be able to be used with zero paints? ///////if you have any comments on this airbrush please let me know.
Thanks
Sam
Old 10-15-2012, 08:40 AM
MidMazar's Avatar
MidMazar MidMazar is offline
Re: Tamiya HG Trigger Type Air Brush
For the price your going to pay, i would go with an iwata. The tamiya is a good brush although over priced. Myself am not a big fan of pistol grip style. This type of airbrush mainly for spraying bigger parts like bodies. I think it would feel awkward using it for small detail IMO.
In Progress
The Following User Says Thank You to MidMazar For This Useful Post:
dynosam (10-15-2012)
Old 10-15-2012, 09:13 AM
stevenoble's Avatar
I've had one since 2006 and it has performed faultlessly in all that time and never let me down. Very easy to use and maintain. Personally I find the trigger style brushes much more comfortable than normal ones. Sure, it can spray heavy wet coats for bodies but it can also spray finer, down to a pencil line thickness, so it's a good all rounder. As for the price and quality issue it's actually made by Iwata for Tamiya so no problems there..
Steve Noble
The Following User Says Thank You to stevenoble For This Useful Post:
Old 10-15-2012, 11:23 AM
Vric's Avatar
Vric Vric is offline
Tamiya airbrush are done by Iwata, so quality is good. But it might be cheaper to get an Iwata depending of where you are from. With 0.3mm needle, you can do small details.
I'm not a fan of pistol handle. but it's a matter of taste.
The Following User Says Thank You to Vric For This Useful Post:
Old 10-15-2012, 11:45 AM
ZoomZoomMX-5's Avatar
I have a gravity-feed Grex w/pistol grip, and quite the opposite...I love it. It can lay on an amazing wet coat on a body, or be adjusted down to spray finer than my Iwata HP-CS Eclipse. The pistol grip is much more natural, IMHO...but then again, I was using a 1:1 spray gun before I got an airbrush. Being someone's first airbrush, it really doesn't matter, since they all work basically the same.
I've heard many good things about the Tamiya airbrush.
My Fotki Album
The Following User Says Thank You to ZoomZoomMX-5 For This Useful Post:
Old 10-15-2012, 07:07 PM
RonCla's Avatar
RonCla RonCla is offline
I'm in agreement with Steve. I've got 3 Tamiya HG triggers.
Two have the .5 tip and one has the .3 tip. Never had an issue with any of them and have always done everything I have asked of them.
The Following User Says Thank You to RonCla For This Useful Post:
dynosam (10-16-2012)
Old 10-16-2012, 12:35 AM
dynosam's Avatar
Thanks for all of the comments guys. I hadn't researched enough and I had no idea that this cost $200+! Are there any cheaper brushes still with the trigger style that are good quality?
Thanks
Sam
Old 10-16-2012, 09:56 AM
stevenoble's Avatar
Thanks
Sam
Iwata do a trigger brush, but I think it's more costly than the Tamiya one. The Grex trigger style mentioned in an earlier post is also around the $200 mark..
Steve Noble
Old 10-16-2012, 01:39 PM
scalecar scalecar is offline
Thanks
Sam
Yes, try this link below. The SB80 model is under $50 with trigger type.
http://www.tcpglobal.com/airbrushdep...mance.aspx#G76
Despite its low prices, Master airbrushes work very well.
The Following User Says Thank You to scalecar For This Useful Post:
Old 10-16-2012, 04:34 PM
88Porsche944 88Porsche944 is offline
Originally Posted by scalecar View Post
yes, try this link below. The sb80 model is under $50 with trigger type.
http://www.tcpglobal.com/airbrushdep...mance.aspx#g76
despite its low prices, master airbrushes work very well.
Old 10-23-2012, 04:15 AM
dynosam's Avatar
So if I was to buy the SB80, what else would I need to buy before I could paint? Could you guys list some good cheap Compressors?
Thanks for all the help.
Sam
Old 10-23-2012, 06:00 AM
RonCla's Avatar
The best deal in compressors will be found in your local Hardware/ Auto Parts stores.
The likes of Bunnings/ Supercheap and Repco will all have home handyman compressors with decent sized tanks that are cheaper than the the little airbrush compressors you will find in a hobby store.
They regularly have them on sale too. At least over here in NZ.
The only down side to the home handyman type compressors is they can be loud when running.
I just turn mine on to fill the tank and then switch it off as a full tank will last me all evening.
Old 10-23-2012, 04:02 PM
Sam
Each brand of airbrush is likely to have a different connector size. So does Masters brand that you are considering. But they do sell adapter to make their brushes usable with other brands of compressors. For example, if your compressor has the 1/4 inch connector, you can ask them what adapter you need to connect their Master brand airbrush to the compressor.
As an example, I put a 1/4 inch to Badger air hose adapter at my compressor output. When I use the Master brush, I use an adapter from the airbrush to a badger hose. The hose is then connected to the compressor.
Hope this helps.
