Old 10-12-2012, 11:40 AM
scubacat scubacat is offline
Rear Jack/Lift point for placing jackstands - 02 Windstar SEL
Does anyone have any suggestions as to where to place my hydraulic jack in the back to lift the rear up all at once? In the front, I put in on the subframe and then place the jackstands on the designated points behind the wheel wells. I've heard of some jacking up by the back axle but given that it was patched on a recall, that doesn't seem like the best idea.
Old 10-12-2012, 12:15 PM
jdl jdl is offline
Re: Rear Jack/Lift point for placing jackstands
Well, you might try a 2x6, make long enough to reach from side to side. Not touch anything but the jack points/frame-rail. I can't be sure that would work without looking at your vehicle. It's just a thought. Be safe.
There are safety issues with raising any vehicle. Safety is your responsibility.
Old 10-14-2012, 06:37 PM
Does nobody else jack up the van from the back? How do you put both back wheels on jack stands to change rear breaks??
Old 10-15-2012, 07:13 PM
12Ounce 12Ounce is offline
I use one jack, and jack stands, on both sides.
Actually, I usually jack one side, lower vehicle onto jack stand ... and then move to the other side with jack, raise that side and leave the jack in place while doing work. If I go under car, the second jack stand gets placed. I have a light-weight 2 ton aluminum jack that is handy for moving about.
Old 10-15-2012, 07:18 PM
... and BTW, I would never use center of the rear axle as a jack or support point! I think it might bend pretty easily.
Old 10-16-2012, 10:20 AM
Thanks 12ounce. Do you jack up at the pinch weld or place your jacks there? Obviously you can't jack at the same spot you place the jackstands!
Old 10-16-2012, 11:09 PM
I use a short length of 2x6 to create space for both the jack and the stand.
The Following User Says Thank You to 12Ounce For This Useful Post:
scubacat (10-17-2012)
Old 10-17-2012, 06:32 PM
Thanks for the tips. I'll try that idea of a block of wood for sure!
