2000 Pontiac Grand Prix GTP Question's
OK here's the skinny. I bought a 2000 pontiac grand prix gtp earlier this year and have been bringing this car back from the dead. I'm still learning a lot about this kind of car since I've never owned a supercharged vehicle before. I have found this "T" connector directly under the supercharger on the side where the belt is located and found a piece of tube (looks like a vacuum tube) disconnected that ran from the back part of the engine. The tube looks as if it needs to be replaced, but the issue is I can't seem to figure out what it goes to or what it actually does. Can somebody help me figure out what this piece is, what size it is, and where I can buy a replacement for it? Thanks ahead of time for any and all help.
Re: 2000 Pontiac Grand Prix GTP Question's
I don't know much about a supercharger. Found this vacuum diagram. If it is a vacuum line, you can take a piece of it to the autostore, tell them you want it that size and tell them how long.
The diagram is for a 3.8L vin1. |
| The Following User Says Thank You to jdl For This Useful Post: | ||
RNLessley (10-15-2012)
If the diagram doesn't help, take a picture of the line you're talking about and where it goes and post it up for us to see.
Do you have the engine running? One thing the diagram doesn't show is the line going to the climate control system...called accessory vacuum. The vacuum line to the cabin goes through the firewall. Regardless get all the damaged or missing vacuum lines and fittings replaced.
I posted two pictures of the vacuum line I am talking about. As you can see whom ever owned this car before me did a botched up job (being nice about it) on the line. I did follow the line and I think it does go to the map sensor but I want to be certain before I start to work on it. Sorry the pictures are so big. The line is right below the supercharger and right above the coolant line. Does anybody know what the sensor actually does for the car? Sorry if I sound stupid but I am no mechanic by any means.
The MAP sensor (Manifold Absolute Pressure) is needed for the engine to operate properly and efficiently. It provides manifold pressure data to the powertrain control module for the fuel injection system. Also, MAP data is used to help control the EGR valve for emissions control.
Important thing is to make sure none of the vacuum lines are bad and properly connected since it will affect the boost control for the Eaton M90 supercharger. BTW - I don't see your pics.
Heres another vacuum diagram for the L67, VIN "1".
'08 Pontiac Grand Prix GXP (Dark Slate Metallic) - LS4 5.3L V8 '02 Oldsmobile Alero GL2 - LA1 3400 V6 '99 Buick Regal LS - L36 Series II 3800 V6 '03 Honda CR250R MX - 2 Stroke 250cc '97 Pontiac Grand Prix GTP - L67 Series II 3800 V6 Supercharged (Sold) Timeslip 08/12/06 AF Community Guidelines Last edited by shorod; 09-29-2019 at 05:06 PM. Reason: Removed spam links. |
| The Following User Says Thank You to BNaylor For This Useful Post: | ||
