HELP!!! 86 Tbird electrical problem some things work some don't (only drive during daylight)
FIXED!!!!
thought you might like to know thanks for your post (at http://www.foxtbirdcougarforums.com) it made me look a second time at the fusible links that just kept testing good. Well the genious that designed this particular piece of the wire harness decided it would not only be special to run the harness under the battery, but to include a connector there as well. When I gave it a tug three wires just fell out of the connector. Cut, Solder, and heat shrink tubing. Hello everyone I am in a state of emergency. Have to get this fixed before saturday or take it off the road. I bought this car in 1995 with 52,000 miles on it, and just turned 150K it has the 5.0 engine with AOD Long story short it sat in the driveway for a few months, but started every two weeks or so. Some things work some don't. Re-seated all the fuses in the fuse block which made it possible to start with the key,,,, Re-seated the headlight switch with no change......still have some "minor" glitches..Hoping it's a loose connection somewhere Question is where to start,,, heading under the car to clean starter and ground... Thinking maybe a relay, but wouldn't know where to start. Just finished checking fusible links ...checked out ok , and tested the fuses with a test light the ones that didn't work mentioned before have no power at the fuse block. The chilton wiring diagram isn't very helpful. they seem to have left out quite a lot. the lighting circuits aren't on the diagram at all. DOES WORK... Fuse 1,2,5,10,14,18 Directionals front and back Brake lights with cyclops hazard lights power windows Wipers horn DOESNT WORK Fuse 4,6,8,12,13,15,17 Clock power door locks Power mirrors power seats odometer does not show numbers (digital) but does light up Headlights high or low beam dome lights ( center and spots) driving lights spent some time on it and concluded all good to firewall, My neighbor who is a mechanic by trade came over and stuck his head in for a look. the high low directional arm on the column was what we found to be a problem. when the arm was pulled back (flash to pass) the battery/voltage light would go out and the fuel pump would run, when released light would come back on and the fuel pump would stop.......now there is some power to ignition but that curcuit is now dead. I took the switch from the column apart cleaned all connections made sure females were tight reassembled with no change
Below is my ongoing project AND IS NOW FOR SALE a 1957 LLoyd 600 body on a 64 International scout frame. Last edited by Doug_I; 10-16-2012 at 08:40 PM. |
