Go Back   Automotive Forums Car Chat > Mazda > CX-7 | CX-9
Old 10-08-2012, 11:37 AM
tbuckit1's Avatar
tbuckit1 tbuckit1 is offline
Send a message via AIM to tbuckit1
2008 Mazda CX7 passenger power window
2008 Mazda CX7 passenger power window works fine from passenger door, will not operate at all from driver's door (master switch). Assumed it was master switch problem so I swapped it out and still have same problem. All fuses seem okay, what am I missing?
tbuckit1
"What in the wide, wide world of sports is a go'in on here?" - Taggert
Old 10-13-2012, 07:54 PM
Mx5guy Mx5guy is offline
Send a message via AIM to Mx5guy Send a message via Yahoo to Mx5guy
Re: 2008 Mazda CX7 passenger power window
If I were u I would pull the passenger switch and check all wires specially the one sending the power from the driver switch to the passenger one there could be an open in it or a loose contact, wire became kinked somehow time to take a look do the wiggle test see if it you can get an intermittent operation at least. A test light may be a great tool u may want to check if the is power feeding the switch properly.
