Old 10-07-2012, 03:57 PM
joslinm joslinm is offline
Hard starting
Have a 98 S-10 4 cyl. Sometimes starts very hard in wet weather. Tries to catch and finally does after a minute of cranking.
Any obvious things I should check/replace first?
Old 10-08-2012, 10:17 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Hard starting
Check for bad plug wires and coils.
May be shorting across or out when wet.
MT
Old 10-08-2012, 06:12 PM
Re: Hard starting
probably could use changing anyway. I think they could be original, at least the coils. They look like murder to change out. Am I right?
Mike
Old 10-10-2012, 08:13 AM
j cAT j cAT is offline
Re: Hard starting
Mike
the spark plug wires when old or damaged because of over heating due to improper routing or no fasteners to properly hold in place cause the resistance to rise. often the resistance will be an open . then when the mositure increases like a cold morning start with dew on the block you get arcing to ground or to other wires .
I would replace the wires and the plugs. use the dielectric grease inside the boot ends.
the other problem you may find is when the wires open , arcing also occurs inside the distributor. inspect for damage , carbon tracking.
the ignition control module[ICM] at this age cannot take much of this arcing. component rapidly overheats which can cause sudden ignition failure when hot.
plug wires properly installed of good quality should last about 10 yrs.
the silicone conductors and insulation after this amount of time should be replaced to avoid engine shut down and loss of power and MPG.
