97 2.2 where is the computer located?
hi i wanna swap out the computer from my 97 sunfire into my 97 cav they both 2.2 and i going to swap ignitions
but where is the computer located its not in the hayes book |
Re: 97 2.2 where is the computer located?
For the cavalier, It should be behind right front facia on impact bar. Passenger side front.
ok i found it now i got the 2 connectors off but how do you get the computer out?
i wanting to replace it since the anti theft stuck on the cav and i just gonna swap out the sunfire computer but i dont see how its hooked up its tight fit in there |
My info says you remove the pcm from underneath. You safely raise and support the vehicle. You should take the negative battery cable loose before doing anything. Remove the right side engine splash guard. The pcm retainer has two bolts that you remove.
and both cars the comp located same location but i dont see how u can pull the computer straight down is there a screw holding it or something?
does it show where the bolts are or what size? i guessing the bolts are towards the tires?
also i pulled off both and forgot which color goes to the outside of the car like blue or black as they both the same pin out but ill look for the bolts |
so i see the one bolt i guess its at the top inside the wheel well but you dont see another bolt
does the headlight have to come out to get access to the next one? any pictures? |
My database showed this. Databases are not always correct. I guess I'd have to look at it? Pictures below.
ok mine kinda looks like the first one with bolt at top i got that one out on both ill look for the lower bolt
does your book or what not say which color blue or black goes into which plug i pulled them out thinking they by different pins but they arent just colors and i forgot but oging to look for that other bolt now |
ok so i got them out database needs to be updated first you need to remove the horn then u can get better access to the bottom bolt but u need a 10mm ratchet wrench and elf sized hands cuz i have no idea how i going to get that bottom bolt back in but what about the plugs the blue and black ones
My database did talk about the horn. I thought once you got at it, you could figure it out. I don't know about the colors you were asking?
ok ya i got it in and stuff the colors are blue and black found it labeled on the other computer
there is 2 harness's that screw into the computer thats why and the one adapter has blue and other is black so i did the change and the ignition but the anti theft is still on why? is there another computer that controls this anti theft i need to change out and if so where is it? |
i also found out it could be the BCM thats bad or the instrument cluster
now is the BCM the same for sunfire and cav? as i know the cluster isnt i dont think one will plug into the other |
If the security system was the original problem, you should have checked for applicable trouble codes before you did anything.
there are no codes shown this happened last year where the i guess orginally the radiator temperature sender tells the car its -40 and pumps more fuel into the engine and then turns a brand new (2 of them) cat's red hot on the intake side and then the engine missfired or what not and then the anti theft system came on after that and car has never ran since so now i had this 97 sun fire that blew the timing chain and well in end not worth fixing the head its another 500 bucks jsut to have that fixed so i wanted to swap parts out from the 97 sunfire into the 97 cav but still no luck
so what would bee the issue? and the code reader still doesnt read any code issues with the cav just the anti theft light is stuck on and using the bypass module from newrockers doesnt work they say its either BCM or intrsument cluster as its supposed to bypass the TDM |
