Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 10-01-2012, 11:06 AM
wetroads wetroads is offline
95 Aurora fuel shut
My 95 aurora 4.0lost all power to the fuel pump and at relay. what could be my problem. Is there a fuel shut off ?
Old 10-01-2012, 11:41 AM
jdl jdl is offline
Re: 95 Aurora fuel shut
Check the fuel pump fuse in the rear fuse-box. Make sure there is voltage where the fuse plugs in, use a voltage tester. My info shows an oil pressure switch in parallel with the relay. Once you crank it enough to bring up oil pressure and switch closes, the fuel pump should run.
Old 10-01-2012, 12:49 PM
I did have the change oil and change Trans fuild notice light. Fuse ok. but will check for power there. thanks
