Old 09-30-2012, 08:01 PM
WRCfan WRCfan is offline
Send a message via AIM to WRCfan Send a message via MSN to WRCfan Send a message via Yahoo to WRCfan
Toyota Celica GT-Four - '93 Monte Carlo
With one buttoned up, time to get cranking on another build. I decided to do something a little old school. The '93 Celica was driven by Auriol and Kankkunen and dominated the season opening round at Monte Carlo.
The kit was obtained from Hobbylink Japan: http://www.hlj.com/product/TAM24125 with my last Peugeot 206 build.
It's a kitset that I haven't seen for a while now on the forums so decided to delve into it.
Work starting tonight!
http://www.hlj.com
Old 10-01-2012, 04:22 AM
generationx's Avatar
generationx generationx is offline
Re: Toyota Celica GT-Four - '93 Monte Carlo
Good luck with this build. I made it a few years ago and the decals were REALLY difficult to work with so if you can source some aftermarket then I would recommend it. The kit itself is really nice.
The Following User Says Thank You to generationx For This Useful Post:
WRCfan (10-01-2012)
Old 10-01-2012, 08:41 AM
Motometalix's Avatar
Motometalix Motometalix is offline
Will you use PE-set for this kit?
The Following User Says Thank You to Motometalix For This Useful Post:
WRCfan (10-01-2012)
Old 10-01-2012, 04:45 PM
@generationx: I have heard similar things so will see how they work out. I know this is a very recent production run of the kit thanks to HLJ being in Japan so will keep fingers crossed.
@Motometalix: This one will be OOB. I will add a little additional detailing in the cockpit but not too much. I will be running a photoetch belt set to the kit however as rallycars always look better being able to see the belts running though the rollcage.
http://www.hlj.com
Old 10-07-2012, 01:36 AM
The kit has been started. Everything has kicked off nicely, suspension has been installed along with the sumpguard and exhaust. The tooling for this kit is actually the 1992 Safari rally Celica which I noticed after spotting the snorkel in the kitset.
The cockpit tub on the older tooling has a lot of the detail built into the floor - extinguisher, footpan etc... A slight challenge for painting however it's a refreshing change.
One cool thing I noticed about the group A rallycars is that they had a 'beefier' sumpguard then, compared to now. Lots of ventilation was used on the older cars via the sumpguard whereas now the suspension is totally enclosed off from rocks as they snap the control arms, and other suspension components much easier nowadays.
Comments welcome as always!
http://www.hlj.com
Old 10-12-2012, 12:26 PM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
Nice to see one of my favorite rallycars in here. Looking forward to this!
olly olly oxen free
The Following User Says Thank You to nugundam93 For This Useful Post:
WRCfan (10-22-2012)
Old 10-13-2012, 07:51 AM
stevenoble's Avatar
Looking very good so far, look forward to seeing more as you progress..
Steve Noble
The Following User Says Thank You to stevenoble For This Useful Post:
WRCfan (10-22-2012)
Old 10-22-2012, 12:08 AM
A little bit more progress has been made. The cockpit tub which was moulded in grey was shot in white and then the black was painted along doors and transmission tunnel.
Rollcage was mocked up in the tub, then glued into one cage and painted.
WRCfan
http://www.hlj.com
Old 10-22-2012, 03:42 AM
Coming along nicely!
Old 11-08-2012, 05:00 AM
A smither of progress tonight on the car. I have assembled the cockpit properly now, added the spare wheel, and then installed some belts as I believe no rallycar model should be without them.
Wheels have had the tyre decals added to them as well and they look quite nice, not as bland as before.
http://www.hlj.com
Old 11-08-2012, 08:52 AM
gbarrbr's Avatar
gbarrbr gbarrbr is offline
Send a message via MSN to gbarrbr
This is one of the most enjoyable kits I ever built. Yours is coming along fine.
Old 11-08-2012, 04:34 PM
ChristopheB's Avatar
ChristopheB ChristopheB is offline
Looking really good so far.
Old 11-08-2012, 04:45 PM
lovegt40's Avatar
lovegt40 lovegt40 is offline
ItaloSvensk
very nice model. Just be careful with decals. mines simply disappear touching water..and cant finish the model for years.
Paolo - LoveGT40 Modelworks
website www.alsoldatino.com
my YT channel : https://www.youtube.com/channel/UCIp..._as=subscriber
FB: https://www.facebook.com/alsoldatino
Old 11-08-2012, 09:47 PM
Thanks for the heads up on the decals. Hopefully being a recent issue there will be no problems with them. Hoping to do decals tonight actually provided things go to plan.
Shall keep you all posted on progress!
Aaron
http://www.hlj.com
Old 11-08-2012, 11:11 PM
sam01contact's Avatar
sam01contact sam01contact is offline
Nice, clean work!
