Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-20-2012, 11:14 PM
mtxplod mtxplod is offline
idle and start issue
I have a 93 2.3L mustang and have been experiencing some issues with it lately. first its hard to start sometimes. It will turnover a few times stop and continue to turnover with no start ( for some reason i have found holding the throttle will make it start). secondly is the idle. when idling if I tap the throttle the engine will bog down slightly and the rpm will reduce to 400 revolutions are so, then idle at roughly 1500 and slowly reduce to 1000ish.
i have cleaned the throttle body,icv,egr,and upper intake
new ignition module and spark plug wires.
also i have a ranger header on it, so there is no pipe feeding the egr valve and have 17 LB injectors.
help greatly appreciated!
Tags
1993 , 2.3 , idle , mustang , problem
