Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 09-20-2012, 04:10 PM
Black_Blade Black_Blade is offline
Trying to determine what type of differential?
Looking through the Dodge service manual and I notice for rear differentials there are several different ones mentioned 9 1/4, 9 1/4AA, 10 1/4, 10 1/4AA, etc. I will at the very least have to replace the pinion seal, its leaking and was wondering what type of lube to refill with and according to the manual its different for the different type of rear end..
I will be taking the back plate off to drain out any old oil and inspect...hopefully will be able to recognize any problems. I am worried something big may be wrong since I am hearing/feeling a noise/vibration whenever I take foot off the gas and coast or slow down for stop lights at low speeds. (I started another post of that issue looking for pointers.)
Old 09-20-2012, 07:32 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Trying to determine what type of differential?
Page 150 in the '01 FSM,
"AXLE IDENTIFICATION
The axle differential cover can be used for identification
of the axle (Fig. 2). A ratio tag is attached to
the top of the differential cover."
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 09-21-2012, 05:12 AM
I was under truck looking around and didn't see any kind of tags, but will look again tonight when get home, if its not raining again!
Old 09-21-2012, 07:50 PM
AF - Advisor
I didn't find one on mine either but the cover has been off before and I guess they chose not to put the tag back on.
Old 09-22-2012, 08:17 AM
Probably same as what happened on mine...so now how to figure out what is best type of lube to use in it..
Old 09-22-2012, 07:49 PM
AF - Advisor
We use 70-90 & 70-140, GL6 non-synthetic lube in the shop racecar differentials and other differentials.
