Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-19-2012, 12:17 AM
dirteemic dirteemic is offline
1992 Chevy Caprice Wagon Transmission Problem
I am having an issue with my transmission. Mine will not accelerate when in reverse, at all. When I take off in overdrive, the car revs up really high until about 30mph and then finally shifts and seems to drive normal at about 45-65mph,after that the car revs really high up to about 70mph (then i slow down). No problems with gear 1 and 2. I have no clue whats going on! Any feedback would be greatly appreciated. Thank you!
Old 09-19-2012, 01:08 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 1992 Chevy Caprice Wagon Transmission Problem
Oil level? It's okay to overfill it by about a quart - try this and see if you have any changes.
Could be a plugged filter, cavitation (loose filter, although this comes with noise - a sort of whine), or a weak pump.
I won't rule out an issue with the reaction sun gear train (most likely the sun shell itself).
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Tags
1992 , chevrolet , chevy , transmission , wagon
