Go Back   Automotive Forums Car Chat > Buick > Century
Old 09-16-2012, 06:01 PM
rmignol rmignol is offline
2000 century low coolant sensor
is it much trouble to change the low coolant sensor
Thanx
Old 09-17-2012, 07:53 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2000 century low coolant sensor
It's located in the right side radiator tank and has a spring retainer. Remove the retrainer and pull the sensor out. You will loose some coolant in the process so have a drain pan ready.
Old 09-17-2012, 09:48 AM
thank you, I went to pep boys for the part, was told need to get the part from a dealer, also was told try to remove the sensor and clean it that should help, will try today Thanks again
Old 09-17-2012, 06:35 PM
got the part at a local dealer, not cheap 83 bucks, looks pertty easy to install,
Thanks again for the info
Old 09-17-2012, 07:08 PM
gmtech1's Avatar
You're welcome. Good luck!
Old 09-17-2012, 07:12 PM
aleekat aleekat is offline
I always use this for a price check. rockauto.com
Old 09-18-2012, 09:38 PM
Tech II Tech II is offline
If the coolant has never been flushed, it could contaminate the new one......
