Old 09-15-2012, 02:55 PM
stuemany stuemany is offline
2007 silverado abs problem
2007 silverado abs brake problem. abs activated at slow speed. abs tester revealed speed difference between the wheels. one was stopped when it wasnt. if you have multi meter you could measure acmillivolts when turning wheel by hand. should be 350. removed wheel sensor, it might break, file lightly surface on hub. this worked for me. it changes the gap between sensor and hub. good luck.
