Go Back   Automotive Forums Car Chat > Buick > Regal
Old 09-14-2012, 01:57 PM
mn_1 mn_1 is offline
Lightbulb 1999 Regal service procedures
Drivers side sway bar broken right next to the link. How hard to R@R the sway bar? (Front)
Old 09-14-2012, 08:43 PM
Tech II Tech II is offline
Re: 1999 Regal service procedures
Not bad, think you have to drop the rear of the cradle a few inches for removal/installation....I would get new bushings too...
Old 09-15-2012, 09:11 AM
GTP Dad GTP Dad is offline
Pontiac Guy
This is a common issue on these cars. The job isn't bad to do as Tech II indicated. I purchased urethane bushings from Jegs for my 97 Grand Prix rather than go with the stock rubber mounts. You can get a new one from GM Performance Parts that is stronger and gives better handling. I don't remember where the one came from when I had to replace it. It was a solid bar from either Andy's Autosport or ZZ Performance. We replaced it by removing both front tires and placing the car on jack stands so that the suspension would droop. Then we turned it upside down and ran it between the rails on the cradle. With a little manipulation we were able to get it in without loosening the engine cradle at all. Good Luck
Old 09-15-2012, 11:39 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
If you lower the back of the cradle, be careful not to go too far as you will seperate the steering intermediate shaft. To be safe, you may want to disconnect the shaft from the steering gear before lowering the cradle.
Old 09-18-2012, 07:51 PM
Got one off a 98 Century from the boneyard for $8. Bushings etc were like new. Not too bad once you move the tie rods out of the way.
