1980 camaro
Ok...
Im wanting to buy a 1980 camaro but it has a v-6 with a 3 spd manual trans. Will a 305 or 350 engine bolt up to the 3 spd trans that is in the car now? Thank you for your time. |
Re: 1980 camaro
It depends on if this car was sold in California.
The California models came with the Buick 231 cid V6, for emissions reasons.The SBC will not bolt up, unless you swap the transmission. Camaros sold in the other 49 states had the Chevy-made 229 cid V6, with is essentially a SBC minus 2 cylinders. So the SBC will bolt up. You should note the 305 or 350 you get needs a pilot bushing hole drilled into the back of the crankshaft. SBC's that came with automatics do not need this hole, but the manual transmission cars do. So...uh......look for the hole ![]() If its not there, a good machine shop can drill if for you. BTW, don't bother with a 305. For the time and trouble involved in the swap, go for the 350. Way better. |
| The Following User Says Thank You to MagicRat For This Useful Post: | ||
badass54 (09-13-2012)
Re: 1980 camaro
It has a 229. So a 350 will bolt up to the trans?
