Old 09-11-2012, 06:17 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Cap/Rotor
1999 4.3 Blazer
Trouble starting after rain, finally no start.
Replaced cap/rotor. Few questions on this. New cap seems to have play to it yet both screws are tight as they go. Rotor seemed say way so I presume it to be normal. After startup, idle seems fine but when applying brakes wants to stall out. Leaning towards vacuum leak in distributor area/throttle body area where I was working. I don't see any hoses that are obviously off. Wires labeled prior to removal so I am pretty confident that is ok.
Was leaning towards maybe the brake booster vacuum line as being loose but I checked that and it seemed tight. Do hear air whistling in there that is not from the fan but can't exactly track it down. Any suggestions?
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 09-11-2012, 09:26 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: Cap/Rotor
Yes, a couple of things, first, did you buy an AC-Delco Cap and Rotor? If not, that might be part of your problem. Second, Double check all of the vacuum lines, both big and small to make sure they're not flopping around or loose. I did that once and when I finally found the biggest Fricking hose on the system laying loose, I felt pretty stupid. Third, remove your distributor cap and look for moisture inside the distributor and also inside of the cap. If you see any moisture, Momma's portable hair dryer will do wonders to dry it up, then put a light coat of grease around the bottom lip of the new cap and re-install and start the truck. Forth, If you buy a Spray can of Carburator cleaner and spray it around the hoses and other areas of where there is vacuum, you might see it suck in, or at least hear a change in RPM. Fifth, One of my older Blazers had a 1/4 inch vacuum line that wrapped around the base of the distributor. The Distributor housing down below the cap burnt a hole in this little stinking hose and it took me forever to find the SOB. Trace all of your vacuum lines with your fingers as far as you can to see/feel for holes, splits, and dry rot etc. Sixth, check your vacuum ball for cracks.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
The Following User Says Thank You to Rick Norwood For This Useful Post:
s10blazerman4x4 (09-12-2012)
Old 09-11-2012, 09:40 PM
Re: Cap/Rotor
Yes AC Delco on both, one thing I noticed was that the cap didn't lock on the top of the distributor but everything lined up.
Ill check for hoses that may be off.
Thanks
The Following User Says Thank You to s10blazerman4x4 For This Useful Post:
Rick Norwood (09-11-2012)
Old 09-11-2012, 09:48 PM
Big Tall Dumb Ass
Re: Cap/Rotor
Thanks
Good Job buying the AC-Delco Cap!
Old 09-12-2012, 09:17 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Cap/Rotor
Wow, Shawn and Rick in the same thread? What is this 2004?
The Following User Says Thank You to blazee For This Useful Post:
Old 09-12-2012, 09:25 AM
Big Tall Dumb Ass
Re: Cap/Rotor
Yeah, well Ya Know some things never change. Where ya been Chris? Ain't seen you in a while?
Old 09-12-2012, 10:10 AM
blazee's Avatar
Problem?
Re: Cap/Rotor
I've been busy rebuilding my meth lab. The other one blew up.
Haha, I've been around I just don't post much anymore.
Old 09-12-2012, 10:11 AM
Big Tall Dumb Ass
Re: Cap/Rotor
Good to know that you are still yuk'n it up!
Old 09-12-2012, 04:36 PM
Re: Cap/Rotor
Only one missing is Mike lol.
Funny thing about this whole thing is I sold this car to my sister in February but everytime it breaks, I get called into service to fix it. It is having seperation anxiety. The wife and I got a 2000 Cherokee now and that thing is a PITA to fix so that usually gets sent off to the mechanic. This is why I had the dumb question about should this cap have play because on the Cherokee, I changed the coil rail and that was pretty painless. No wires to mess up, no screws to lose.
Old 09-12-2012, 04:37 PM
Re: Cap/Rotor
I think what happens is the old guard just moves on and we just leave our knowledge in the forum for others to find via the search button. But every once in awhile the old guard reunites on here.
Old 09-12-2012, 07:56 PM
mike1224's Avatar
mike1224 mike1224 is offline
Send a message via AIM to mike1224 Send a message via MSN to mike1224 Send a message via Yahoo to mike1224
Re: Cap/Rotor
I heard my name being called... and 2004 was a decent year for me blazee, lets head back.
2002 Chevy S-10 ZR2
Originally Posted by balls_to_the_wall
Some people are alive only because its illegal to kill them.
The Following User Says Thank You to mike1224 For This Useful Post:
Old 09-12-2012, 08:00 PM
Re: Cap/Rotor
Not bad for me either.
Looking like Saturday I get another look at this. Will report back then what I see.
Old 09-13-2012, 07:48 AM
Big Tall Dumb Ass
Re: Cap/Rotor
Aw C'mon we need BlazerLT just to mix things up LOL.
Old 09-13-2012, 03:21 PM
Re: Cap/Rotor
That was the first thought that went through my mind but didnt want to fire up the maple leaf. Haha
Old 09-13-2012, 03:38 PM
Big Tall Dumb Ass
Re: Cap/Rotor
Chicken!
